Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: symptoms of a clogged exhaust
  1. #1
    Default symptoms of a clogged exhaust
    my truck is starting to run rough again. it's doing this kind of intermittent lurching thing. it's been increasing in frequency.
    i wonder if this might be due to the exhaust getting clogged up again. this has happened once or twice before with similar symptoms.
    i'm wondering if i should cut off the cat and muffler and see what happens.
    el presedente and community organizer
  2. #2
    You'll shoot your eye out
    Join Date
    May 2006
    Location
    Smyrna, Ga.
    Posts
    401
    Rep Power
    Default
    Oh man, tell me you didn't fall for the old "banana in the tailpipe" gag again, did you?
  3. #3
    Default
    cut that cat out...you don't need it in Walton County.
    I'll Keep My Guns and Money And You Can Keep The Change
  4. #4
    Default
    well sunday i am going to cut out the cat and gut it.
    not exactly sure how i'm going to get it back on there, though.
    apparently 3" exhaust pipe isn't a standard size that autozone has.
  5. #5
    Highbars Highbars's Avatar
    Join Date
    Apr 2009
    Location
    along the Mississippi, Bellevue,IA
    Posts
    374
    Rep Power
    8
    Default
    A plugged exhaust usually is not intermittent.. Plugged exhaust will cause power loss under load conditions or higher R's.. It can only take in what it can get out .. It is usually best to qualify all the systems you can first.. Ignition , fuel, Power and grds, vacuum...etc. Isn't this an '89 chev.? If so does it ever stall going around a corner sometimes?
    Oh GOD... I'm Going to Hell... Giddy-up!
  6. #6
    Default
    ignition should be fine - i replaced rotor, cap, plugs and wires last month. ECM is only about a year old.
    i cut out the cat today. it was stopped up to a degree. for now i replaced it with some 3" metal dryer vent from home depot. i'll drive it around some later and see how it goes.
    no stalling around corners, usually.
  7. #7
    Default
    ok so yeah... back pressure ruptured the dryer vent. had to use some flashing to fabricate some pipe until i can get it to the shop.
    it does seem to be running a little cooler, though!
  8. #8
    Senior Moderator LMS's Avatar
    Join Date
    May 2006
    Location
    Georgia, where it's fucking hot and humid.
    Posts
    1,965
    Rep Power
    Default
    I have seen a cat come apart and the chunks went down and stopped up the muffler.
    I have only seen this once though so can't say that that's your problem. How does the cat look inside? If it looks broken that may be your problem.
  9. #9
    Default
    it looked like a little grid, most of which i could see through.
    about 25-30% of it looked stopped up.
  10. #10
    Default
    so the muffler was full of debris. i ended up getting a 3.5" diesel-grade exhaust system for $150.
Similar Threads
  1. 472 Exhaust Manifold Needed
    By JustGrim in forum Want to Buy
    Last Post: 03-08-2009, 12:24 PM
  2. Where should I go for exhaust???
    By VAMP3D in forum Dead Ends
    Last Post: 12-19-2007, 08:27 PM
  3. Dual Exhaust
    By badkitty in forum Technical
    Last Post: 09-25-2007, 09:00 AM
  4. Exhaust manifold is needed
    By tonytheskin in forum Want to Buy
    Last Post: 02-16-2007, 11:47 AM
  5. 1971 Exhaust manifolds
    By Needles in forum Want to Buy
    Last Post: 07-20-2006, 12:28 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
